Thanks, I saw it, I want to know which connector and pin in the BCM the door ambient lights are connected to, I know that the footwell lamps are connected to the C2280G Pin 13 connector and to the C2280F Pin 4, but the door ambient lighting is controlled separately and that's what I need. The US and EU versions have the same BCM. My track has ready door wiring for Ambient lights, I connected the original RGB LED Lights to them which I bought from the Dealer and activated in Forscan but they do not light up, there is probably no wiring between the BCM and the A-pillarNot sure what you want to do, but this thread may help.
A owner got creative and modified the lights
Modifications to the Ambient lights is a challenge due to the fact that the light output (Intensity and Color) control is on the (LIN) circuit.
This circuit is also monitored by a FET, so any changes in voltage output affects the circuit.
Ambient Light Modification/Update | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
[BCM]>C2280D/38> -VDN13(BN/WH)- >C275/20> --VDN13(BN)- >C213/13> -VDN13(BN)- <C556/2<[FRONT DOOR RELEASE AMBIENT LAMP LH]
\-VDN13(BN)- >C238/10> -VDN13(BN)- <C620/2<[FRONT DOOR RELEASE AMBIENT LAMP RH]
