Wires Going Into Transfer Case Connector Broken
COLMtnRanger
I was on a gravel road and heard something hit bottom of truck. Immediately got TMS Fault and 4x4 Fault. When I investigated, two wires going into transfer case connector were broken. I assume they were hit by a rock flying up. Questions: 1) Can the wires be simply spliced? 2) Can that connector be ordered so there is a longer length of wire to splice? 3) Hoping I don't have to replace the entire cable harness? Thanks!
RangerBill
PA
If the wires are not broken right at the connector, you should be able to splice them. You should make sure that the splices are waterproof.
