Wheel spacers slight vibration
njrucci
nick
york pa
2019 ford ranger
I have 1 inch wheel spacers on front and rear. When I get to 80-85mph the seats shake. I had my tires road forced balanced twice. Tire size 32 10.5 R17
You use hub centric rings? I don't and don't have any issues...but it could be a problem if you don't have rings and torque them down carelessly...
njrucci
njrucci
nick
york pa
2019 ford ranger
they are torqued right. I wounded if the stock wheel studs are to long.
First, do you have hub rings? Second, by torquing correctly, I mean the method used. I don't have rings so I rely on "lug centricity"...by which I center the wheels/spacers by slowly tightening the lugs in star pattern and increase torque round and round until final 100 ft/lb...also, this needs to be done with the wheel/tires jacked off the ground...
njrucci
njrucci
nick
york pa
2019 ford ranger
I don’t have rings. But I did torture just like you said
I hope you didn't "torture" it lol...seriously, you might consider going back to zero state...remove the spacers and test drive...if that got rid of the vibration then examine each of the spacers for differences...there might be one that's out of spec...if all the same...try reinstalling again carefully and see if the problem persists...all else fails, I'd ask for a refund...which brand did you get btw?
njrucci
njrucci
nick
york pa
2019 ford ranger
yea I have been messing with them all day. I had them on for like a year and thoughtmy tires were out of balance. So I got them road forced balance and still have the same problem. So right now I am only running the front spacers because then it doesn’t shake. And the brand was cheap that’s why I think they are the problem
I think that may be the issue...I got mine from:
https://www.uswheeladapters.com/
I actually used their Taco adapters and have been very happy with them...
