conductor
- First Name
- Rog
- Joined
- Apr 25, 2023
- Threads
- 9
- Messages
- 61
- Reaction score
- 81
- Location
- 6z7DxXWKDVuLN9
- Vehicle(s)
- 2020 Ford Ranger
- Occupation
- retired
- Thread starter
- #16
Yeah Ford really screwed the info display menu up.Agreed, “Truck info” seems more intuitive but for my 23’ XLT tremor “Truck info” shows power distribution, the steering angle, and the pitch/lean or whatever it’s called…seems like a better spot to put the tire pressure as well..
also someone asked what is power distribution for.. well I suppose off-roading it could help you see which wheels a doing the work to help get a feel for what your truck is doing with its feets. But idk for sure what the actual purpose behind it is.. the one that shows degrees of angle can help you not get close to rolling… but if you’re getting that sketchy chance is if you get that far you should probably be ready to well you know?..
sounds like tire pressure has been found…
it would be nice to petition/complain/suggest to ford to change the coding and put the tire pressure readings in the truck info menu as it seems fitting to be there (and oil life.) rather than driver assist like lane keeping, pre collision, etc. small detail but it would be a welcomed change in my opinion.
Oil life, and tire pressure should be in the big list when you go to it, not 3 deep under a wrong heading. This is what happen when you let the engineer who figured where it is to go, change the order, like some word scramble !
