Tacoma A-Pillar Brackets?
Glocker
Boca Raton
I'm curious to know if anybody has adapted Tacoma A-pillar light pod brackets to work on our trucks. They are substantially less expensive than the ones purpose made for our trucks.
SafetyDan
Dan
Oxnard, CA
I have a set of the hood mounted Tacoma light brackets on my 2019 Ranger. The work just fine.
Glocker
Glocker
Boca Raton
Care to share a link to the exact brackets? Thank you in advanced!
SafetyDan
Dan
Oxnard, CA
The issue is that these cam off my 2013 Tacoma. They were made by Fab Four. I can post a photo of the brackets, but they do not have a PN.
Glocker
Glocker
Boca Raton
Actually that info is very helpful. I think around 2015 or 2016 the brackets change.
Glocker
Glocker
Boca Raton
Glocker
Glocker
Boca Raton
Try them out and report back, amazon has a good return policy.
another option i am thinking is https://www.amazon.com/dp/B07B931B3...colid=M80K7OMJEBG4&psc=1&ref_=lv_ov_lig_dp_it
I'm not too crazy about the idea of using those clamp on style mounts. I'm concerned about them pinching or dimpling where they clamp around the hood, or become loose and marring the hood or sliding off.
I'm off the idea of ditch lights for the time being. I may revisit it later!
SafetyDan
Dan
Oxnard, CA
Update - I did not take into consideration the crazy wiper arms at full swing they hit.
Glocker
Glocker
Boca Raton
Ouch! I hope you can maybe make some kind of adjustment to the bracket, or something!
SafetyDan
Dan
Oxnard, CA
The could be cut and welded. I just mocked up a set that mounts on the hood bracket but moves the light toward the outside of the truck.
scubalizard
Houston
2019 Ford Ranger XLT
Just found out the same. I am just going to adjust the wipers so that they don't hit the mount. It will limit the wiping of the windshield, but I don't think it will be bad.
JNSnyder
Jake
Indiana
Did you end up getting the wipers adjusted?
