- First Name
- Chris
- Joined
- Mar 15, 2020
- Threads
- 164
- Messages
- 7,550
- Reaction score
- 10,761
- Location
- Elizabeth, Colorado
- Vehicle(s)
- 2012 Nissan Frontier, 1994 F150 XL, 2022 Ford Transit
- Occupation
- Field Service Technician
Depending on tire and tire size it may be possible that trimming and crash bar modifications can be avoided even with 33's(I myself and a few pthers on here have experienced such).I agree with you. I was just writing why control arms are good. Yes if the coil overs are extended travel, uca are needed.
If crash bars are modified and OP did some trimming they could put a bigger tire.
As for extended travel it really depends on how much extra travel you are talking about. Pretty much all the aftermarket shocks available for tgese trucks are extended travel compared to stock including the shucks from Old Man EMU. As long as the suspension kit is designed to work well and get the factory alignment back into specifications then control arms arent necessary. The only way ir becomes a bit different is when you go to the crazy baja kit that replaces all the control arms both top and bottom. Even with that they still use the same struts if you weren't doing that baja kit. If anything the shocks would have different valving due to the extea leverage.
