Should I lock my truck doors while in "neutral tow" and being flat towed?
Jan
Indianapolis, IN
2022 Ford Ranger SuperCrew Lariat
Last step in setting vehicle in Neutral Tow on my truck says:
"9. Leave the transmission in neutral (N) and switch your vehicle off by pressing the push button ignition switch once without pressing the brake pedal or turning the key as far toward the off position.
Note: Vehicles with keys do not turn to the off position when the transmission is in neutral (N). You must leave the key in the ignition when towing. Use the keyless entry keypad or an extra set of keys to lock and unlock your vehicle.
10. Release the brake pedal."
Now, for safety consideration, is it acceptable to then lock the vehicle's doors (via Keyless Entry Handle) while traveling with truck then in tow?
Hi Jan,
That is what I have been doing since 2019 when flat towing my Ranger....
Marty1096
Marty
Arizona
question: lost 2nd set of keys. will the Ford Pass lock and unlock truck doors in neutral tow mode?
canyonslicker
Andy
2021 Ranger Lariat
65 YO Juvenile Delinquent
Interesting step 9 says push the button once and don’t touch the brake. Step 10 says release the brake. I’m confused.
Release parking brake?
best,
