Ranger Wildtrak 2016 2.2L Engine EGR ISSUE
Renie
Anthony
Philippines
Wildtrak Ranger
My pick car has an entermittent DTC “EXHAUST GAS RECIRCULATION CIRCUIT “A” HIGH”. I measure the signal voltage and have a reading of 0.85 volts when egr valve is close. I also measure a 2.0 BI TURBO Engine 2019 wildtrak and have a 0.52 volts when egr valve is close.
My question was, what is the normal signal voltage of 2.2L engine?
Base on my voltage reading above in 2 different engine which are not the same, Does the EGR signal of 2.2L Engine must be 0.52 volts like the 2.0 BI TURBO and because it producing 0.85 volts when the valve close was the cause of that “ EGR CIRCUIT “A” high code.
Thanks for anyone might help n diagnosing my car.
