Ranger Ford Performance Fox Suspension Kit on Sale!
Status
Not open for further replies.
Stage3Motorsports
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
For anyone in the market, On sale and in stock ready to ship!
2019-2023 Ford Ranger Fox "Tuned by Ford Performance" 2.0 Suspension Kit M-18000-RA
Highlights:
  • Huge improvement in both on and off-road handling
  • Add up to 3" front & handle 1.5" rear leveling
  • Pair of Fox 2.0 front coilovers & 2.0 rear shocks
  • Reduce rake while improving handling
  • Gas-charged monotube internal reservoir design
  • 2" diameter aluminum shock bodies with Eibach spring
  • Drop-in replacements for stock
Complete Package of Front & Rear Leveling
While the 2019-2023 Ford Ranger is certainly capable of getting through off-road terrain, adding some leveling parts can give you a better ride and prevent damage to your midsize truck's bottom. If you're going to raise the suspension of your front, you might as well get some rear suspension upgrades as well. Our friends at FOX and Ford Performance have teamed up to offer a fantastic 2.0 Suspension Kit for you to upgrade your Ranger all in one place and all for one price!
3" of Front Suspension for 2019-2023 Ford Ranger
This pair of FOX 2.0 IFP Performance Series Front Coilovers have an adjustable ride height from 0" to 3" of lift, making them an effective leveling system to stay scratch-free on rocky terrain. The coilovers come pre-set at 2" for 4WD trucks and 2.5" for RWD trucks out of the box to reduce rake and add tire clearance without putting your truck too high. FOX designs each of their 2.0 coilovers from the ground up to get you maximum performance, improved response, and much better articulation off road.
Built for Performance and Reliability
Each FOX 2.0 coilover is built around a tough aluminum-body, nitrogen-charged coilover shock that's wrapped with a finely-tuned spring that work together to provide excellent suspension performance off-road. While some leveling kits sacrifice ride quality for suspension, these coilovers work without compromising your truck's smooth street ride. Both the body and mounts are made with 6061-T6 aluminum to maximize heat dissipation without losing strength. The coilovers feature a 5/8" chrome-plated, heat-treated shaft with a high-flow piston design and valving that's tuned for your Ranger. The coilover has an internal reservoir design that keeps the specially formulated oil separate from the nitrogen. The 2.0 coilovers have high-quality, redundant seals that make them extremely reliable under even the most extreme conditions.
Improved Rear Suspension Performance and Articulation
The 2019-2023 Ford Ranger's factory rear shocks could perform better when hitting intense off-road trails and don't always work with front end suspension upgrades. Heavy articulation and long wheel travel push factory shocks beyond their valving and can cause problems. This pair of FOX 2.0 aluminum-body rear shocks will replace your stock rear shocks and make your rear suspension just as ready for the trail as your truck's front leveling. Each of these 2.0 FOX shocks can easily handle an extra 1.5" of lift on your truck's rear and were carefully designed to improve articulation, wheel travel, and heat dissipation which makes them one of the best and least-expensive off-road shocks out there.
Aluminum Shocks with Specialized Piston and Valving
Each shock features a body and mounts that are made from 6061-T6 billet aluminum to dissipate heat much more efficiently than standard steel shock absorbers. This helps keep fade minimal under heavy articulation. The shocks both have a high-flow Internal Floating Piston (IFP) design built inside a chrome-plated and heat-treated steel shaft with Ford Performance tuned valving that gives them impressive performance and response. They also have high-quality redundant seals that help improve reliability in aggressive applications and off-road driving. The shock installs directly in place of your stock shock making for simple installation.
Fitment: 2019-2023 Ford Ranger
Status
