po171
ozzy
bob
bucks co. pa.
2022 ranger
I have a 2022 fx4 check engine light just came on po171 code any thoughts just hit 25k.
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
Vacuum leak, O2 sensor Is it idling rough?
This code is one of the most difficult to T-Shoot as there are a number of variables that can trigger it. (Sys Lean) so PCM is adding Fuel to compensate.
You can view freeze frame data and note anything that stands out (this is a snapshot) of the PID data at the time the code was triggered.
Most generally this boils down to a vacuum leak (unmetered) air - or too much air over fuel
You could reset the code and see if it returns and also burn off at least 1/2 tank of gas - as bad gas is another possibility and fill up.
If the code is persistent then it needs a Live Data monitor to assist in pinpointing down Vac Leak, Fuel Delivery, PCV or EVAP issue or a lazy O2 sensor.
For the visual inspection - ensure all hose and tubing (air induction) is secure and the air filter is clean.
ozzy
bob
bucks co. pa.
2022 ranger
code popped 20 miles after fill up at giant reg. grade
