pedal tuner
Buddyshelton
Buddy
Naples Fl
2019 Ranger Lariat Supercrew
Has anyone tried a pedal tuner yet? either pedal commander or K&N
t4thfavor
Chance
If you want more power go with a real tuner, else just use S mode. The pedal tuners just change the angle of the throttle plate in real time, not something I'd want it doing as they don't tune them special for each vehicle.
OffroadAlliance
Brockton, MA & Houston, TX
www.offroadalliance.com
2019 Ranger, 2021 Raptor, 2022 F250, 2023 Bronco
The Pedal Commander is a great little part. And it definitely works in conjunction with "S" mode.
You must have noticed that when you step on the gas pedal with the intention to overtake a slow-moving car or just beat the guy next you, there is some lag between your foot mashing the skinny pedal and your engine reacting. This is because the digital signal from the pedal first goes to the engine control unit, which eventually transmits it to the motor for action.
The Pedal Commander is designed to reduce the delay in the signal between throttle and engine. It basically speeds up the signal thus eliminating the delay. Not only that, but the Pedal Commander offers 30+ individual settings allowing you to fine tune the the sensitivity of your gas pedal to your exact desire. There's even an Eco mode designed to help slow the pedal to save increase fuel economy. Or turn it up to the Sport or Sport+ modes and get near instant response!
Install takes minutes and can easily be removed. It does not reprogram the vehicles ECU so there aren’t any footprints for the dealer to see. It does not add any horsepower or torque. While it feels like you’re gaining power, it’s actually just removing the throttle delay and causing the vehicle to react faster. These are now Bluetooth enabled allowing you to adjust settings on your phone in addition to the unit itself.
As always, use discount code PC5 for 5% and free shipping. These are in stock and ship out right away.
Link ---->>>> OFFROADALLIANCE.COM
