OEM LED Headlights DRL function help please
Lsteele87
Lewis
Arizona
Transit Connect
Energy Management
Just got ahold of the OEM LED lights for my 22 Lariat Scab since they were deleted from the build on ordering, installed them and they are great but the DRL function is not working, went into forescan and enabled it but can only get them to work when low beams come on. Can anyone explain what i need to do in forescan to have them working normally, from what i saw everything was setup in forescan like a Halogen truck since the Leds were not installed due to the shortages back then.
Copy & Paste from this thread
Ref: Post #69
I highly suggest you also view Post #70, for the reason of the DRLs staying on with tuck off.
Aftermarket Headlights - Wiring & Issues (Group Help) | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
Set these exactly as noted, and they should be working as if the truck rolled out of the factory with the LED Headlamps.
Undo - everything you have done so far and ONLY change these settings up to;
END OF REQUIRED SETTINGS, this will get the lights working the same way it would if the Halo's were never installed.
Then adjust / tweak your desired alterations from the factory settings.
The settings required to swap from Halogens to LEDs (Factory) As-Builts
to match the Factory Settings.
Most of these settings can be found in the Easy Menus
DRL DTC Inhibit LF & RF DRL & Position Lights
726-24-01 - 0000-00C0-D0E2 (Halo)
726-24-01 - 0000-0000-D022 (LED) -xxxx-xx0x-xxxx
0=Normal - All (4) Lights
C=Inhibit (Inhibits only the DRL) Lights-Position Lights Normal
Frequency Select
726-26-02 - 0000-0002-0057 (Halo)
726-26-02 - 0000-0001-0056 (LED) xxxx-xxx1-xxxx
0-Type (0) LED - 1=Type 1 (LED) 2-Type 2 (Halo) 3= Type 3
Moves the DRL from Low Beam to (Dedicated DRL Circuit)
This automatically changes 726-50-01 to (108E) 10 = Dedicated DRL
When (Dedicated DRL) is selected it Powers Pin #6 at the Headlight assembly
VRMS Target Select Configure
726-29-01 - 0000-0000-0259 (Halo)
726-29-01 0000-0000-0158 (LED) xxxx-xxxx-x1xx
0= Type (0) LED - 1=Type 1 (LED) 2=Type 2 (Halo) 3= Type 3
This ties to 726-26-02 (Power Output) and they need to match
Note: This does not auto-change when the above 726-26-02 is changed
DRL Lamp Mask Configure
726-45-01 0A01-0200-0080 (Halo)
726-45-01 0A01-1000-008E (LED) xxxx-10xx-xxxx
01=DRL (Disable) -02=Low Beams - 04=Front Fogs - 08=Front Turns 10-Dedicated DRL 20=Hi Beams
40=Low Beams +Dedicated DRL 7F= (All of the above options)
This allows + additional DRL options (if desired) if none leave this as (10)
DRL Lamp Configure
726-50-01 0280 (Halo)
726-50-01 108E (LED) - 10xx
01=DRL Disabled 02=DRL Low Beams 04=DRL Front Fogs 08=DRL Front Turn Lamps 10=Dedicated DRL 20-DRL Hi Beams
40=DRL Low Beams +Dedicated DRL
This ties to (what is the main DRL Circuit and this also applies Power to (Pin#6) Dedicated DRL Circuit (10)
LF & RF DRL Circuit Configure
726-61-02 - 1600-0000-01A7 (Halo)
726-61-02 - 1601-0100-01A9 (LED) - xxx1-x1xx-xxxx
0=Not Used 1=Used
This setting changes between (Halo & LED) as the DRL has been moved
Extras: (Optional Additions) for Lighting Settings
FOGs on Turns
726-26-01 - 0100-0003-0058 - xxxx-x1xx-xxxx
0=Disable 1= Enable
This allows the FOG's to be cornering lights on turns
DRL Include Park Lamps
726-26-02 - 0000-0002-0057 - x1xx-xxxx-xxxx
0=Disabled 1=Enabled
This will allow (Side Marker & Taillamps & License Plate Lights) On with the DRL's
DRL (Switchback) w/Turn Signals
726-26-02 - 0000-0002-0057 - xxx1-xxxx-xxxx
Front Fog's with High Beams (Bambi Mode)
726-27-01 - 0100-0001-0057
0=Allow 1=Inhibit
DRL With Fog's
726-71-01 - 0064-0A00-000D - xxxx-xxxx-x0xx
0=Allow 1= Inhibit
Canada (Lighting Settings) - Noted Differences Between the US & Canada Version for DRL Lighting
As I was curious and also T-Shooting on how to get the DRL's on (Always) and what Ford did for
the Canada Law Change in Sept 2021.
Canada BCM Changes:
Feature Configure DRL by Auto Lamp Person 1-4
726-16-02 - 0202-0202-024F (Canada-LED) x2x2-x2x2-xxxx
726-16-02 - 0101-0101-014A (US Version)
0=Disabled - 1=Enabled - 2=Inoperative
This Disables the IPC (Selection) Input from the IPC Menu
Feature Configure DRL by Auto Lamps Vehicle
726-16-02 - 0202-0202-024F (Canada -LED) xxxx-xxxx-x2xx
This Disables the IPC (Selection) Input from the IPC Menu Note: When you DE-SELECT the DRL Lighting in the IPC Menu this changes to (1) from (0) Enable to Disable Canada (Removes) This Input and the Menu as well.
Feature List to BCM (DRL) by Auto Lamp Initial Value
726-21-01 - 1401-0001-0267 -(Canada-LED) -xxxx-xxxx-x2xx
726-21-01 - 1401-0001-0166 (US Version)
0-Disabled - 1=Enabled -2=Inoperative
This Disables the IPC (Selection) Input from the IPC Menu & This sets the (Default) value
for the above - (726-16-02)
726-24-01 - 0000-0000-D022 - (Canada -LED)- xxxx-xxCx-xxxx
726-24-01 - 0000-00C0-D0E2 - (US Version (Halo)
726-24-01 - 0000-0000-D022 - (US Version - LED)
0=Normal C=Inhibit
So, this stays the same if you have LEDs
726-26-02 - 0100-0001-0057 - (Canada -LED) - x1xx-xxxx-xxxx
726-26-02 - 0000-0002-0057 - (US Version (Halo)
726-26-02 - 0000-0002-0057 - (US Version (LED)
So, Canada (REQUIRES) this addition
VRMS Target Configure
726-29-01 - 0000-0000-0158 (Canada -LED) - xxxx-xxxx-x1xx
726-29-01 - 0000-0000-0259 (US Version - Halo)
726-29-01 - 0000-0000-0158 (US Version (LED)
DRL Options
726-45-01 - OA01-1000-008E (Canada -LED) - xxxx-10xx-xxxx
726-45-01 - 0A01-0200-0080 (US Version (Halo)
726-45-01 - 0A01-1000-008E (US Version LED)
So, this stays the same if you have LED's
DRL Lamp Configure
726-50-01 -108E (Canada -LED) - 10xx
726-50-01 -0200 (US Version (Halo)
726-50-01 -108E (US Version LED)
DRL Lamp Circuit Configure
726-61-02 - 1601-0100-01A9 - (Canada -LED) - xxx1-x1xx-xxxx
726-61-02 - 1600-0000-01A7 - (US Version Halo)
726-61-02 - 1601-0100-01A9 - (US Version LED)
DRL W/Fog
726-71-01 - 0064-0A00-010E (Canada -LED) xxxx-xxxx-x1xx
726-71-01 - 0064-0A00-000D (US Version Halo)
726-71-01 - 0064-0A00-000D (US Version LED)
0-Allow 1=Inhibit
Canada is set to (Inhibit)
Canada IPC Changes:
DRL Screen (Option) DRL Lighting
720-02-01 - 4DA5-345D-1ECB -(Canada LED)- xxAx-xxxx-xxxx- DRL Screen / xxxx-xx5x-xxxx
720-02-01 - 4DE5-343D-1EEB - (US Version)
E=Enabled A=Disabled -and 3=USA 5=Canada (Country Code)
This disables the IPC Menu selection from the screen from showing. I suspect if you leave this and with the associated (BCM Changes) the selection will be greyed out.
So, all Ford did was Force the (Park Lights) to be included with the DRL lights and eliminated the
(Auto-Switch) function of the DRL's and also eliminated the (user) control to turn them off.
End of Canada Changes
