looking for 2019 Ford Ranger Wiring Harness Diagrams
dokkerdam
jim
Ticksnout, Maine
2019 Ranger STX SuperCab
airline pilot
does anyone have a 2019 or later Ranger wiring harness diagram they can share. i am specifically looking for the part of the diagram that shows the wiring and plugs to the front headlight/turn signal assemblies.
my vehicle is a 2019 XL. I'm trying to install older style plow lights and need to identify the parking/driving light wire and the two turn signal wires so i can splice in and wire those to the new plow lights.
thanks to all.
Its all covered here
The parking lights MAY not be an issue, however the Turn Signals will most likely not function without errors as the BCM is very finicky with the turn signals and may possibly give you Hyper-Flash (IPC) indication or it may completely disable the circuit.
The Parking Light - feed can be T-Harness off of either side marker light, they make a harness for that but if I recall there is not a (T-Harness) for the headlight connector.
You may want to research that before you start splicing into the harness, I always prefer to (T-Harness) in before any splicing.
FYI - I would not tap into the Park/Turn bulb socket wiring as its part of the headlight assembly and Ford does not sell just that socket (only the complete assembly)
Ebay shows a replacement socket but unknown if it will actually fit and lock into the headlight assembly.
Aftermarket Headlights - Wiring & Issues (Group Help) | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
dokkerdam
dokkerdam
jim
Ticksnout, Maine
airline pilot
thanks,
i'm trying to avoid the Snoway EIS energy interruption system and the lights i have are old Dietz buckets with turn signal wings.
i get what your saying about the turn signal problems. longing for the days of that 1st generation bronco.
jim d.
p.s. the ranger is going to Rowe Ford for their comped state of maine inspection. i'm hoping i can talk them into looking at the diagnostics for the mode actuator without a $150 labor charge.
