Has anyone changed out a front passenger door window switch?
ChiefQM
Bill
Hiram, GA
2019 Ford Ranger XLT
My 2019 Ranger XLT has suffered a partial failure of the front passenger side window switch. The window will lower from the passenger side switch, but will not rise. The window will lower and rise from the driver's switch, and the lockout is not engaged. All the other switches work, both at their relative door sites and from the driver's switch.
While I have an extended warranty, there is a $100 deductible and the replacement switch (EB3Z-14529-AA) is only $47. How hard is it to change the switch?
Thanks!
Colo_Ranger
2021 Ford Ranger XLT FX4
Thanks!
its ridiculously easy. Once the door card is off (even loose, if you're only doing the switch) you can unplug, remove, and replug the new switch.
Spacenut
Michael
Great Lakes
2021 Ranger Tremor
Also check the plug to make sure a wire hasn't backed out of the insulator once you get it apart.
