upnorthranger
- Thread starter
- #1
Just picked up a Weboost Overland and looking for tips on hardwiring this into the truck. I currently have it setup with the antenna cable snaked through the rear sliding window and powered through the cigarette lighter. Looking to connect it directly to the battery with the antenna wired into the cab somewhere without going through the window. There is also an internal antenna that needs to reside inside the cab. Would like to wire it to one of the factory Tremor aux switches with ignition bypass so I can switch the booster on without turning on the ignition. Any thoughts or advice?
Weboost Drive Overland
