Halogen headlamp bulb replacement
jdjeff
Southeast PA
2021 Ford Ranger XLT
Anyone care to share the easiest way to replace the halogen headlamp bulbs (low and high beam) on a 2021 XLT? It's the passanger side that giving me the most trouble.
OFC Ranger
Jack
ZR2
Not sure what to offer, both headlight rear caps are accessible without removing anything. The passenger side is a bit tighter to work with if you have Andre the Giant sized hands.
If you are having trouble getting the bulb out, carefully find something to assist disconnecting the plug. I found this will give you more wiggle room to rotate the bulb better to pop it out. Yes for some reason, the passenger side bulb can be a PITA if you leave the harness connected to it.
jdjeff
jdjeff
Southeast PA
My hands and lower arms are average size. Seems like it's the window washer fluid fill that's in the way. I can barely get the caps off. Once the caps are off, the rest seems impossible. Am
I going in the wrong way? I just though maybe there was some kind of trick to this.
OFC Ranger
Jack
ZR2
Face forward, reach hand back in that way so your wrist can bend to get to it. If you try and fool with while facing the engine bay yea its a weird angle. The passenger side for me was one of those things I had work it without looking at it.
jdjeff
jdjeff
Southeast PA
Ok...I got it. The connectors were easier than I thought they would be. But seems like the only "trick" is like you said, face forward. I held the washer fill out of the way with my other hand which also helped. Thanks for chiming in on this.
