H E L P >>> with Gator EFX install. Have you done it yourself?
FULLSCALE
Adam
Ontario, Canada
They do drain out there. If you stick it through those holes far enough and then look up from underneath on the passenger side you can see the end of the hose. You can’t see it on the drivers side because the fuel filler is in the way.
BHunted
Sumner County, TN
I tried yesterday to get the hoses in there. They are too big for the smaller holes on the side and the one in the corner top is too high. The hose bend is lower than the hole. Like a drain trap. Oh well.
BHunted
Sumner County, TN
Which holes you refer to? Just want to clarify....
FULLSCALE
Adam
Ontario, Canada
I don't have the truck here with me but they are at the front corner of the bed up high near the front. There are two sort of rectangle shaped holes that don't quite line up above one another. I have an Undercover Ultra Flex so the hoses could be a smaller size... mine barely fit in the hole. I used the bottom one and it was just a little lower than the barb on the tonneau rail.
Rp930
Denver
I used the same holes for the MX4 and yes they barely fit in but it works.
