Going up in tires size just a little
Mighty Little Blue
Wisconsin Rapids, WI / Philippines
2021 Velocity Blue Supercab FX4
Printer/Retired
You got that tire on stock without problems?
Not stock
I have Fox 2.5 Coilovers set to 2.5 lift and BDS Crash bars using Method 316 18 x 9 wheels +18 offset, and with that setup there is no rubbing.
OrangeStreak
New Mexico
Have the K02's 265/70/17 and love the ride and handling. Checked carefully for rubbing and there is none at all. The closest they come to any surface is 1/2" The biggest variation is when the speedo shows 75 mph, the Garmin GPS shows 78.5. The other speeds show less variation. Always use the Garmin on extended trips.
Largest Tires on a Ford Ranger (Biggest Tires, No lift) – 4WheelDriveGuide
