Floorboards soaked
NetRedding
R
2019 Ford Ranger Lariat FX4
Has anyone had any issues with water leaking into the cab? After a large rainstorm, I found my floorboards soaking wet. The carpet under my floormats were dripping. I'm not sure if the water came in when parked, or when driven thru smallish puddles on road.
2019 Ranger Lariat FX4
66F100
Justin
MD
2020 2WD XLT SCAB
Lineman
I've had clogged cowl drains, clogged sunroof drains, and clogged AC condensation drains cause wet floorboards. No problem on the Ranger, just other vehicles. Do you park under alot of trees with falling leaves and debris?
BGDOGY
Tommy
virginia
2019 Ford Ranger Lariat 4x4 crew cab
halligan1201
Byron, IL
2020 Ranger
Emergency Management
There's been a couple who found the rubber around the wiring harness coming into the cab was installed backwards, allowing water to flow in.
