First towing question
mark_anderson_us
Chicago
Ford Ranger Lariat FX4 2020
Software Developer
Hi all
just starting to flat tow my 2020 fx4 lariat. Should turn off ignition and lock doors with key. (I have the handles that
Lock unlock the car)?
thanks
mark
Hi all
thanks
mark
Hi Mark,
Nope....use the door touch....Imperative fact it to leave the shifter in Neutral...not park. Otherwise you will damage the transmission as Park reengages the transfer case....
mark_anderson_us
Chicago
Software Developer
Hi Phil
owners manual says
if your vehicle has intelligent access, press the engine START/STOP button once without pressing the brake pedal. You do not need to leave your keys in the vehicle. You can lock and unlock your vehicle as you normally do.
this is saying I should turn off ignition and take key with me, no?
flawlesspoop
heritage
United States
phrazle.co
Car
Pharmacist
With smart access, you may start your automobile by just pressing the start/stop button once. You need not stress about losing your automobile keys. You're free to utilise your car's regular locking and unlocking mechanisms.
mark_anderson_us
Chicago
Software Developer
Hi Phil
owners manual says
You should NOT leave your keys in the car, because you will be locked out. Even when flat towing, the doors lock when the vehicle moves. I wasn't sure first time I towed, but knew I could unlock with the Ford app (which I did need to do).
Also, if you don't turn off the ignition, your battery could go flat (ask me how I know)
