Expedition One front bumper install
D60
CO
JL
Also note that in order to install this bumper you must cut the OEM fender "flare." This is not a criticism as it is no secret and clearly laid out in the instructions.
In fact, I think it's a brilliant use of Ford's body lines. The cut is placed such that the remaining piece looks finished because you leave the inner wall of the marker light "box". This leaves it looking capped with virtually no sign that anything was modified.
I prefer to use an OMT to cut plastics myself. Abrasive wheels generate considerable heat and gum up.
Here's a screenshot of E1's instructions. Not terrible for once, although the pics are small, low resolution and can't easily be expanded or blown up. Larger pics online or clickable thumbnails would be nice and cost the manufacturer so little (if anything):
Note the included black and white page of above is nearly useless. I wasn't about to start cutting into someone else's nice truck based on small gray scale pics, so at least I could find color online.
Here's the right side I did. Of course you can dress the cut with a file, utility knife, etc
If you cut it right, I think this is one of the coolest features of the Expedition One bumper. Bravo!
D60
CO
JL
Here's a vid of guys installing the same. I can't say I found it overly helpful, but I didn't mind it. These guys are goofy but I appreciate their keep-it-positive attitude.
Note when they get to the point of attempting to set body lines, they seem to struggle. They also have multiple jacks under the bumper and attempt to hammer it back with rubber dead blows.
I asked in the comments if they had issues with the marker lights, but they just said everything fit "but barely." They also said "everything about the bumper was a pain," but that's relatively vague. It also appears they had no sensors installed in the bumper at the end.
I understand most people aren't going to watch the vid. I'm merely trying to compile more data points for those seriously considering it
YaBoiNewton
Florida
Automotive Engineer
which can suck up HOURS or more.
It is crazy to think of the amount of times one of my vehicles has been left sitting on jack stands because the "simple" job I signed up for had vague instructions or needed some OEM tool. I always realize this once I'm past the point of no return.
You live and you learn. ?‍♂
Reactions: D60
D60
CO
JL
A little more tech (term used loosely) for those who may install this themselves. The two central sensors need their harness to basically run behind the fairlead. This isn't really the fault of @Expedition One and their spacing on these two holes is only about 1/2" wider than OEM:
Anyway, I hate to remove factory harness tape but it's necessary here. I un-taped the harness and was able to break out the right side sensor wires, making for WAY more length:
Cleaned up with some plastic loom and Tesa tape, finger indicates the wires I broke out:
Also note in the upper pics the raw steel exposed in the ID of the holes from drilling to ~30mm. I don't worry too much about rust in CO (and it seems they're no longer using mag around here for ice mitigation, which is AWESOME), but I didn't want my customer to see rust creeping around the sensor holes in several years.
Everyone has "their" paint methods, but here's a suggestion if'n you's a simpleton like me: I have these huge Q-tips which are awesome for sooooo many shop things.
I soak one in rattle can Rustoleum by just spraying to saturation and swirl it in the ID of the hole. I learned the hard way Rustoleum runs stand out on the E1 paint (later cleaned up with a bit of non-chlor brake cleaner on a rag), so protect below the hole with painters tape:
D60
CO
JL
There's not a provision for a plate, which I'd say is fine as winch bumpers should be about strength, additional protection and mounting a winch.
I don't think it's inappropriate to leave plate mounting to the customer.
The owner here said he's extremely unlikely to add additional lighting any time soon, so he gave the green light to bury the fog lamp hole. I just drilled and tapped a couple 1/4-20 holes:
D60
CO
JL
Ok well pretty much closing this out. The project is finished and here's some overall shots.
Overall front view. Perhaps if you zoom you can see the reveal at bottom of right headlamp is not great. Left is better but not perfect. I'm personally confident I did all I could in this regard.
Another shot biased to right side
Right headlamp gap.....meh (or bleh)
Right side body line is not great at all. It is not touching the body despite appearances.
Left side not much better. I had these rolled back with ratchet straps seen elsewhere in the thread, but once tightened down this is where it sits.
I still think it's a very cool bumper overall!!
