Clock on dashboard
Streffie
Nathan
UK, Midlands
2019 Ranger wildtrak 3.2 Auto
The time has flat lined on the dashboard since making some changes today, has anyone else had this issue ?
Not sure what you mean - "flatlined". You mean it isn't displaying any longer or the time is not changing any longer?
At any rate, I've not seen that behavior in any of the FORScan mods I've done.
Streffie
Nathan
UK, Midlands
Fixed ! Such a sillily over look, after I had done a few changes, the clock on the dashboard just didn’t read, it just showed _ _ ; _ _ so I changed everything back to factory, and had the same.
It turned out to be the time needed resetting on the infotainment system, even though the time on there was right ? I then made all the changes I wanted, and reset the time again, and all was ok.
I've been looking for a tasteful aftermarket permanent dash clock...I'm tired of looking for the time on the Sync depending on what mode you're in...sometimes it's on top...sometimes on the side...sometimes not at all...and all the time tiny and hard to read WTF?!:curse:
