Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
6x139.7mm ICON Compression 17x8.5" Titantium Finish 25mm Offset Wheel 2017858357TT
Highlights:
Who says you can't balance form and function with your 2019-2022 Ranger's wheels? ICON's Compression series 17x8.5" wheel is uniquely designed to maximize caliper clearance and optimize wheel position for unhindered suspension travel and steering function. This rugged wheel's dimensions have been strategically designed to minimize scrub radius and improve handling and ride quality. If you're looking to make a splash off the pavement and show off on the streets, you can't go wrong with the Compression 17x8.5" wheel by ICON.
Aluminum Alloy Construction and Titanium Finish
This sharp-lined, concave spoked ICON Compression Wheel measures 17x8.5" with 5.75" backspacing and a 25mm offset. The titanium wheel features a standard 6x139.7mm bolt pattern that fits your Ranger's hub without modifications or wobble bolts. Constructed with lightweight, durable aluminum alloy, the Compression by ICON is built with a reduced unsprung weight and rotating mass to get you through the toughest trails. Best of all, the wheel does not add a ton of excess weight.
Wheel Specifications:
Highlights:
- Uses sharp lined, concave spoke design
- Heavy-duty aluminum alloy construction
- High-quality titanium finish
- Standard 6x139.7mm bolt pattern
- Sold individually
- Size: 17x8.5"
- Bolt Pattern: 6x139.7mm
- Offset: 25mm
- Backspace: 5.75"
- Max Load: 2500lbs
- Hub: 93.1mm
