Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
6x19.7mm Bolt Pattern fifteen52 Turbomac HD Classic 17x8.5" Wheel - Carbon Grey (0mm Offset) THCCG-78569-00
Highlights:
The fifteen52 Turbomac HD Classic Wheel is one of the most unique and aggressive light truck wheels on the market, and makes for an awesome upgrade to your midsize truck. Designed with input from the legendary Ken Block and tested out on Ken's own Ford Raptor, the fifteen52 Turbomac HD Classic is strong enough to survive even the most extreme applications while making your 6x139.7mm bolt pattern vehicle look like one of the toughest trucks on the road. The Turbomac HD Classic features a unique dual-spoke pattern design that's combined with a classic stepped lip for modern vehicles.
Cast Aluminum Construction with Hubcentric Design and Aggressive Offset
Each Turbomac HD Classic is built extremely tough and will survive whatever application you have in mind for your truck build. The Turbomac HD Classic is made out of monoblock cast aluminum that's then expertly machined into the wheel's final look. This version of the Turbomac comes in fifteen52's Carbon Grey finish with a black classic stepped ring that is sure to turn heads both on and off-road. The wheel features a standard 6x139.7mm bolt pattern and a stock 106.1mm hub bore, which makes it a fully hubcentric wheel. The 17x.8.5" Turbomac HD Classic features a 0mm offset and 4.75" of backspace which pushes it farther than stock to help you clear wide wheels and add an aggressive stance to your truck.
Wheel Specs:
Fitment:
Highlights:
- Awesome off-road styling
- Influenced by Ken Block
- grey finish with classic stepped, grey lip
- 0mm offset and 4.75" backspace
- Cast aluminum construction
Wheel Specs:
- Size: 17x8.5"
- Bolt Pattern: 6x139.7mm
- Offset: 0mm
- Backspace: 4.75"
- Max Load: 2500lbs
- Hub Bore: 106.1mm
Fitment:
- 2019-2021 Ford Ranger Ranger w/ 6x139.7mm bolt pattern
- 2021 Ford Bronco 2-Door & 4-Door with 6x139.7mm bold pattern
- 2010-2021 Toyota 4Runner 6 lug w/ 6x139.7mm bolt pattern
- 2005-2021 Toyota Tacoma 6 lug w/ 6x139.7mm bolt pattern
- Will not fit Bronco Sports
