Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
I Figured I would bring some of the individual wheel options to the forum, the Icon Rebound in 17x8.5 is in stock in both the TItanium and Bronze finish.
If anyone is in the market shoot me a message for forum pricing.
Frank
2019-2021 Ford Ranger ICON Titanium Finish Rebound 17x8.5" Wheel +25mm Offset 1817858357TT
2019-2021 Ford Ranger ICON Bronze Rebound 17x8.5" Wheel +25mm Offset 1817858357BR
Highlights:
Wheels not only can look gorgeous and unique on your 2019-2021 Ranger, but also more useful than stock counterparts. ICON's Rebound series 17x8.5" wheel is uniquely designed to allow for unhindered suspension travel and steering function. This rugged wheel's dimensions have been strategically designed to minimize scrub radius and improve handling and ride quality. If you're looking to make a splash off the pavement and show off on the streets, you can't go wrong with the Rebound 17x8.5" wheel by ICON. Aluminum Alloy Construction and Titanium Finish
This ICON Rebound Wheel measures 17x8.5" with 5.75" backspacing and a 25mm offset. The wheel's standard 6x139.7mm bolt pattern doesn't require modifications or wobble bolts to your hub. Constructed with lightweight, durable aluminum alloy, the Rebound by ICON excels off-road without any unnecessary weight. It weighs 30 pounds but can support a load rating of 2750 lbs. This titanium wheel with gorgeous painted rock rings and a black lip ring are much more than just a stylish accessory.
Fitment:
Wheel Specs:
Frank
Highlights:
- Improves looks & stance
- Finished in titanium
- Has a 5.75" backspace
- Features a 25mm offset
- Sold individually
Fitment:
- 2019-2021 Ford Ranger with 6x139.7mm Bolt Pattern
- 2021 Ford Bronco 2-Door & 4-Door with 6x139.7mm Bolt Pattern
- Will not fit 2021 Bronco Sport
Wheel Specs:
- Size: 17x8.5"
- Finish: Titanium or Bronze
- Bolt Pattern: 6x139.7mm
- Backspacing: 5.75"
- Offset: 25mm
- Hub Bore: 93mm
- Load Rating: 2750 lbs.
