- First Name
- Chris
- Joined
- Mar 15, 2020
- Threads
- 169
- Messages
- 7,699
- Reaction score
- 10,977
- Location
- Elizabeth, Colorado
- Vehicle(s)
- 2012 Nissan Frontier, 1994 F150 XL, 2022 Ford Transit
- Occupation
- Field Service Technician
So perhaps you don't have 33s on your truck? You probably don't have a to neither do you? I have both. Does the engine put out more torque than a naturally-aspirated four-cylinder? Absolutely it does. When you're putting it on your load you still have way more torque do to boost compared to a naturally-aspirated. Will you be at full Boost when putting under said load? Maybe, maybe not. It all depends on the conditions you are in at that time. Also just because you have low range does not I mean $35 okay on stock gears. These trucks came stock with 30in tires. Yes we may have a 10-speed transmission which is freaking awesome but that does not make up for the gears in the final drive. When these trucks are driving on the street most of the time a grevior will be necessary when going bigger than a 33 to drive the truck efficiently. There are conditions with my truck that 10th gear is not acceptable. And yes that is a 70 miles an hour. So just because you think we have a ten-speed and that automatically makes it to where you can run 35 be aware you are going to be incorrect because we do not have such short gearing for that. With that said once gearing becomes available it's down to the owner of the vehicle to do some checking with your speed calculator to find out what would be the most correct year set for their application.Right so in 4lo at 2500 rpm it's really isn't making any more torque than a non turbo 2.3 would.
As far as gears, off road I don't think a regear is needed until 35s at least. If you are just in drive the truck actually starts in second and that still plenty low for 33s and even 34s. On road gears might help the trans hold 10th or 9th up small grades, or bring back a slight amount of fuel economy from the bigger tires.
I deal with building 4wd vehicles every day and it's the best midsize to not have to gear power and transmission wise.
I feel that once more gear sets become available we will see an issue of people over gearing their trucks and causing issues of gear bouncing on the highway.
