AUXITO
Diamond Sponsor
- First Name
- AUXITO
- Joined
- Feb 19, 2025
- Threads
- 63
- Messages
- 96
- Reaction score
- 71
- Location
- California
- Vehicle(s)
- 2019 Ford Ranger
- Occupation
- AUXITO Senior Manager
- Thread starter
- #1
Hey Ranger Nation,
Let's be real: the factory headlights on our trucks are a safety hazard on unlit backroads and job sites. You deserve to see more than just 50 feet ahead.
We built the all-new 2025 X5 Series LED Headlights to end the compromise—giving you brutal output, bulletproof reliability, and a clean beam.
ENGINEERED FOR THE RIGORS OF TRUCK LIFE
1. 170W // 32,000 LUMENS – LIGHT UP THE BACK 40.
→ Translation: This is work-site brightness. Illuminate dark barns, spot deer in the ditch, and see your entire trailer load at midnight. No more guessing games.
2. 9-30V VOLTAGE RANGE – FOR WHEN IT'S -20°F AND YOU NEED TO GO.
→ Why It Matters: Handles voltage drops from plows, winches, or inverters without flickering. Stable light in extreme cold or heat is non-negotiable, and now it’s guaranteed.
3. SHARP, CLEAN BEAM PATTERN – SEE FAR, WITHOUT THE GLARE.
→ The Respectful Upgrade: Engineered with a precise cutoff that puts light on the road, not in oncoming windshields. It’s SAE-compliant, so you won’t blind other drivers—or attract unwanted attention from law enforcement.
4. ADVANCED COOLING SYSTEM – BUILT FOR THE LONG HAUL.
→ Durability You Can Trust: A 20,000 RPM turbo fan and die-cast aluminum body work together to kill heat. That means no light decay over time and a lifespan rated for 60,000 hours—longer than you’ll probably own the truck.
5. 100% CANBUS READY – PLUG. PLAY. DRIVE.
→ Zero Hassle Installation: Plug them in and you're done. No error messages, no flickering, no extra resistors. Your Ranger’s computer will recognize them instantly.
6. 360° ADJUSTABLE COLLAR – DIAL IN THE PERFECT BEAM IN 60 SECONDS.
→ The Alignment Game-Changer: A simple unlock of the collar lets you rotate the bulb to the exact position for a perfect, glare-free beam pattern. Align it once in your driveway and forget it.
WHY RANGER OWNERS ARE UPGRADING
For Towing: See around your trailer with wider, brighter peripheral light.
For Farm & Ranch Work: Light up fields and outbuildings with daylight clarity.
For Early Mornings & Late Nights: Make those dark winter commutes safe and stress-free.
For DIYers: A true 10-minute install with zero electrical headaches.
READY TO SEE THE DIFFERENCE?
Shop the All-New X5 Series for Your Ranger Here:
https://auxito.com/collections/x5-series-led-headlight-bulbs
Questions? I’ll be in this thread all day. Ask me about fitment, specs, or installation.
Stay bright and drive safe,
— The AUXITO Team
— The AUXITO Team
