3” level lift fits 2wd/4wd
RetArmy
Belfair, WA
2019 Ranger STX
Equip. Operator
Made in the USA From 1/4” plate steel and DOM tubing. Grade 8 corrosion resistant hardware and coated with stainless steel coatings to resist the harsh elements. Provides 3” of lift for that aggressive proper leveled stance while adding room for larger tires up to 33x12.50 Does not void factory warranty. Precision engineered so there is no stress or binding on ball joints, tie rods, or CV axles. $215 with free shipping. 10% member discount. Lifetime warranty. Email [email protected]
Since I still tow a bit I followed your advice and got the 2 1/2"s. Installed them a couple weeks back and couldn't be happier = Thanks Robby! Now just gotta save the money for tires.
Fordrangerlifts.com
Fordrangerlifts.com
Robby
Las Vegas
fordrangerlifts.com
2019 ford ranger Fx4
Fabricator
Looks great. Can’t wait to see it with the new wheels and tires.
Rene Michaels
SOLD IT
TX
Ordered my rangerlifts 3" leveling kit on 10/29 (Order: R192773005). Looking forward to receiving it and installing! Will post before/after pics later.
Rene Michaels
SOLD IT
TX
Got my RangerLifts 3" kit last week and took it to my trusted mechanic for professional install. The install took then 3 hours followed by an alignment at a cost of $550. I'm loving the improvement in the ride ...the stock ride has that undulating bounce, the kit eliminates that completely without adding any stiffness at all! Front ended up 1 inch lower than the rear from ground to top of wheel well (see attached pics).
Before/after pic below...
BDUb
Kevin
San Diego, California
2019 Ford Ranger XL 4x4, Magnetic
I just ordered the 3" leveling kit yesterday! Cant wait to install it!
Rene Michaels
SOLD IT
TX
Couple of questions - do you have any recommended installers in the Austin, Texas area? I saw there’s a 10% discount mentioned the first post, is a code needed to get the discount?
Looking to place my order this week.
Thanks!
Did you ever get your leveling kit installed? I'm in Cedar Park and Austin's Automotive Specialist in Cedar Park installed mine https://austinsautomotivespecialists.com/
RangerCoby
Coby
Manchester, TN
2019 Ranger Super Crew Lariat FX4
Is it required to modify or replace crash bars with aftermarket ones to fit 33s with this lift?
Justdown808
Just
Hawaii
Ford ranger 2019
I'm actually very disappointed in this lift. I followed your video for the install but you did not mention anything about cv axle nuts. I potentially fucked up my axle by not knowing this. I'm going to disassemble everything and re do it. But as it stands somethings wrong with my axle and theres clunking because theres was nothing said about the differences between 4wd.
Justdown808
Just
Hawaii
Ford ranger 2019
Also this video does not mention anything about changing the orientation of the top strut bolts. You popped the strut down to reveal an already assembled spacer. That's * rest of the fucking owl* kind of tutorial.
