trying to change the themes on sync with forscan
RAYJAY
UNION DALE PA
2020 ranger pickup 2019 subaru
2020 lariet just updates sync, trying to change to Lincoln timeless tried to change and will not work any ideas ??
Sync 3 ThemeAPIM7D0-03-01xxxxx*xxxx--0=Ford Classic, 1=Ford Timeless, 2=Lincoln Timeless, 3=Lincoln Next
xxxxx2xxxx--Lincoln Black Theme -- must also
set 7D0-01-02 8xxx xxxx xxxx
Cabose-1
Eli
Student
Make sure you hit write to make the change and follow instructions prompted on screen.
Or maybe uninstall and then reinstall forscan on you device.
I had to reinstall when changing from my 2020 to my 2022 ranger
RAYJAY
RAYJAY
UNION DALE PA
Or maybe uninstall and then reinstall for-scan on you device.
I did the write on a couple of the numbers no changes the strange thing is the 2 is all ready there?
Cabose-1
Eli
Student
Switch for hs, ms in the right position? Ill try and play with it today. If not tomorrow, see what exact steps i take to change it. Mine is on the bronco splashbscreen
RAYJAY
RAYJAY
UNION DALE PA
yes switch is correct made other changes, did find this on a focus site ?? can't try till weekend and have to pull my tun out before i try it
7do-02-02 xxxx-x*xxx-xxxx
RAYJAY
RAYJAY
UNION DALE PA
They say to ditch the switch. Current approved cable has no selectable switch.
mine works fine. allready done the panic deactavation ,rear timer for power Bambi mode 2 honk delete start up screen on sync ect ect just can't change the themes..
