Spark plugs
Anyone know the difference between Motorcraft SPARK PLUG CYFS12YT4 and CYFS12YT? I know the second one is stock. Thanks.
Hi Sid,
Could this 4 be that this is a 4 pack of spark plugs? I vaguely recall it was a 4 pack. Just a guess...always ran Champion in my race car as they gave two boxes free each year...
Porpoise Hork
Bret
Houston
IT
Hi Sid,
You would be correct sir. It's the same plug, just in a 4 pack.
Well thank you gents for the fast reply...I was about to install them but notice the number and also the connector tip was yellow instead of red...wasn't sure if that it was hotter or colder...do you think the yellow and red makes any difference?
Also, I notice there's other variants with 3 at the end? 3 pack?
The SP534 CYFS12YT3 plugs were superseded with the SP580 CYFS12YT4 plugs. They have the same heat range, and from what NGK indicates there may have been issues with the SP534's and similar variants causing misfires.
So the 4 designation at the end does not mean 4 pack? How is SP580 CYFS12YT4 different from stock SP580 CYFS12YT?
TheKracka
Klay
St. Louis
2019 XLT FX4/2005 xB
I fix things not people
I have a different part #
Motorcraft SP578 Iridium Spark Plugs (4pk) Ford CYFS12YPT
rltriumph
Vermont
2020 Ford Ranger Lariat
Pipefitter
With the part numbers changing is the gap still .030?
Porpoise Hork
Bret
Houston
IT
Honestly Ford has too many variants on their plugs, and what applications they are for... Really causes some confusion when looking for the right one. Especially then they supersede one version for another but are still available for purchase from retailers.
Everything I can find is the actual part number for this plug is SP580 CYFS12YT4 and is listed for the 3.5L and 3.7L V6's. It is available in singles from Ford, comes up as a 4 pack from most third party vendors with a couple also having a 6 pack of the same part number. The only mention of the CYFS12YT I can find is from a few international vendor sites but when pulling it up it lists as a 4 pack and packaging shows it as SP580 CYFS12YT4. Also as @TheKracka mentioned the SP578 CYFS12YPT plug is the correct plug for the 2.0L I4, 2.7L I4, and some 3.0L and select 3.5L V6's.
