Plug and play.
phil 750
Peoria Az
2019 Ford Ranger Lariat
2019 Ford ranger. Replaced the mirror turn signal, right works, left does not. Tested to see if voltage was there. None. Moved the left to right, it work's. Any ideas?
First - Do the front and rear turn signals work?
Have you tried cycling the Hazzard Switch? and does it work with Hazards?
Try a code reset and a BCM Self-Test with Scanner or Forscan.
If the above no help, then you will have to break down the harness and find where it has lost connection.
Next up the chain is C210 pin #19 and then C237 pin # 47, will locate if needed but I have a feeling the above actions will reset it to working order.
phil 750
Peoria Az
Thank you! I'm a novice at this. I'll try what you suggest. Again, thank you.
