Installing the Roadmaster Brake Light Relay 88400
lgwilks
2019 Ranger XLT
AMT
Had anyone installed this on a 2019 Ranger XLT? First, get differing information if this is necessary.
? I am using Instructions A as no push to start. Reading through instructions again, what fuse have you found works best in step 6. I am installing blue ox non binding bat and using Patriot II supplemental braking, RM-15627 wiring kit. This gives me 12v to run to the battery, will also install auxiliary 12 v 20 Amp socket to power the supplemental braking. Would appreciate your thoughts and helpful suggestions.
lgwilks
2019 Ranger XLT
AMT
Base plates and wiring kit installed and per Roadmaster for my vehicle use B instructions for install of relay kit. Remaining items, brake relay kit, 12V outlet kit, battery charge line and Patriot braking system with break away. Any words of wisdom from your install are apprecited.
