Brake light wire?
bobkat
Florida
2019 ford ranger fx4
Retired electrician
I need to tap into the brake light wire off the brake pedal in order to run a monitor light in my motor home . Does anyone know which of the four wires coming out of the brake pedal switch I need to tap?
I believe the purple wire ford left for a brake controller in the harness is Energized when the pedal is depressed? Can I use this wire
I’m going through a six way trailer connector to an led in the dash of the motor home
FULLSCALE
Adam
Ontario, Canada
t4thfavor
Chance
The purple wire reads 12v to ground when the brake is pressed. It also is accessible in the 7 pin connector at the rear bumper.
treimche
Troy
FORT MYERS, FL
2019 Ranger SOLD. 2005 S2000
Accountant
It's hard to see in your pic, but does the purple wire have a white stripe? My resource says the brake wire should be purple with a white stripe. If you want, you can also grab the brake wire in the driver's kick panel, in a black 59 pin plug, pin # 11.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Only if it came with a tow package. But if it came with a tow package then it’s already pre wired for a brake controller
bobkat
bobkat
Florida
Retired electrician
Does that purple wire for the controller do the same as th
yes it looks like purple / white stripe
bobkat
bobkat
Florida
Retired electrician
I do have the tow package
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Do a little research, if you have a tow package you should already have 4 wires ready to be hooked up to your brake controller.
t4thfavor
Chance
They are trying to hook up a brake light in the dash of their motorhome which I assume will be flat towing the Ranger. So it's not exactly a brake controller in the traditional sense. Probably a good idea to ask the questions rather than assume their application is the same.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Well excuse me. But either way it would be easier to use the wire from the brake controller since it’s all ready to be hooked up. Just trying to help. Good luck
t4thfavor
Chance
Please read the rest of the thread is all I can say.
I_smell_like_diesel
Western Maine
2019 Ford Ranger FX4 Lariat
Self Employed
Hi Bobkat,
If you're still in need to help, I can PM you the wiring diagrams for the Braking System.
Regards,
bobkat
bobkat
Florida
Retired electrician
Thanks... I'll give the purple wire a shot.... better than doing one of those taps into the brake wire
