Expianger
Does Sumo Springs offer anything that may help?
They have a generic type part that you insert into the rear coil spring.....doesn't stiffen it up but restricts the compression so it "feels" like the spring is stiffer. Looked at it, but decides against as there is a better, although more expensive route of new rear springs/shocks.
Knock wood, the prior owner never towed, and the suspension doesn't feel worn. I think adjusting the hitch head a bit higher and adjusting the bar chains will take care of the sag.....but it tow's beautifully with no bottoming out and no sway.
I'm now in an F150 and have a similar opinion about the F150gen14 forum.
I tried to have a fun post about the infamous @AzScorpion tailgate damper and it got so serious.
The Expy comes with 6......yes, 6 dampers.....two for the hood, two for the rear hatch, and two for the rear glass which opens separately from the hatch.....
6 dampers.....Dave should be proud !!!!!!!
Most likely all are uneducated and need some serious phycological help! :crazy:;)
Very proud!😍
🤔 So proud I now might have to rethink the whole Camry purchase and look at the Expedition. :shock: 😅
