Arizona Eibach Pro-Truck Lift Kit
Desert_5G
Eric
Arizona
Tacoma
Selling since I no longer have the truck. Kit also comes with the 1" blocks for the rear. $250 firm. Phoenix, AZ. Pickup only.
Manufacturers Specs Found Here
Desert_5G
Desert_5G
Eric
Arizona
Tacoma
smithj3701
Hickory
2021 Cactus Grey Ranger
Would you consider shipping or are you still set on local pickup?
Desert_5G
Desert_5G
Eric
Arizona
Tacoma
Desert_5G
Desert_5G
Eric
Arizona
Tacoma
bump. Still available for pick up only.
Cableranger
Abraham
Chicago
Ford Ranger
Cable tech
Would you take 250 ? I’ll have someone pick them up
Desert_5G
Desert_5G
Eric
Arizona
Tacoma
Cableranger
Abraham
Chicago
Ford Ranger
Cable tech
Does it firm up the ride ? Tried to dm but couldn’t send you a message . Still interested
Desert_5G
Desert_5G
Eric
Arizona
Tacoma
I can only speak from the FX4 suspension. But it does eliminate that soft bouncy rebound that plagues the FX4 struts.
Cableranger
Abraham
Chicago
Ford Ranger
Cable tech
Do you have any pictures of how the truck looked ? Feel like 3 inch lift is too much but want to see to make sure
Desert_5G
Desert_5G
Eric
Arizona
Tacoma
Keep in mind these are slightly bigger tires than stock in addition to the lift.
Reactions: EJH
Cableranger
Abraham
Chicago
Ford Ranger
Cable tech
I’ll take it off your hands then . I’m currently running 265/65r18 and get slight rub at full turn . Just one last question these would work with 2wd ?
Desert_5G
Desert_5G
Eric
Arizona
Tacoma
I can't be completely sure. If it was the 4x4 I would say yes. But I don't know for certain on a 2wd.
Cableranger
Abraham
Chicago
Ford Ranger
Cable tech
Called them up and said it is a different part # for 2wd . Springs are a bit different but will call me back and see if 4wd would work . I’ll let you know for sure once they get back to me
