Diode Dynamics SS3 Light Pod (Fog Light Replacement Kit Pre Order)
Status
Not open for further replies.
themikeyan
LA, CA
19 Lariat FX4
That said, they were great in use on an off road trail in the snow
As mentioned by Mike...make sure you place a spacer between each of the four adapter bracket mounts to back the fog back away from the opening trim. This is needed to allow you to aim the fogs down enough to be of use. For some reason, spacer were not mentioned or included in Diode's kit. They are in Baja's version. I used 1/8"+- thick nylon washers from Lowe's hardware...I can get an accurate description when I'm off work...
Status
