93 octane in/around Denver?
arbjosh
Josh
Denver, CO
2021 Ranger Fx4
Arborist
Anyone know where I can find 93 octane in the Denver area? I get a gas card from work if I have to use my truck (2 employee limit in work truck due to covid) and plan on taking advantage of that lol.
There used to be a Petro Station on Parker Rd. that had 93. Doubt they're around anymore though.
Probably wouldn't see much difference. At our altitude 91 is just as good.
arbjosh
arbjosh
Josh
Denver, CO
2021 Ranger Fx4
Arborist
Sounds good. I'm considering buying a 93 tune. Would I be able to run that on 91 or should I look for a 91 tune?
Check with your tuner.
But in my experience a 93 map will be fine here on 91.
Rp930
Denver
Another reason that makes the FPP Ford tune desirable. Only 91 is required.
Apples
Alan
Roswell, NM
2019 Ranger XLT
The Denver area doesn't need any higher octane than 91 due to the altitude. It is essentially equivalent to 93 octane at the lower altitudes. If you want a bit more power, at the expense of a lower MPH, find a station with E15 instead of E10.
THLONE
Thom
Tucson,AZ
internet wise guy
I see by the weather you are knee deep in snow and cold. No need for more horsepower. Sprinkle a little MJ in each tank. :rockon:
