Another Tire Question
giovanni1
Ontario
2019 Ranger XLT FX4 Off Road
I have the 2019 FX4 Off Road. I believe that it has the 2.5" front spacer lift on it. I purchased it like this so I am not exactly sure. It has 265/70/17 on the stock Ford rims. The inside of the tire is very close to the arm. Maybe 10mm??
I would like to go slightly larger tires. Nearby there are stock wheels and tires advertised from a 2025 Tremor. They are 285/70/17.
Is the suspension different on those vehicles? The wheel offsets seem to be the same on both vehicles. With the 285 I dont think they would clear the inner arm on my truck.
YaBoiNewton
Florida
Automotive Engineer
Pretty sure there was no 2025 Tremor, but besides that point it is not likely that 285/70r17 tires will fit your truck. As you said, clearance to the spindle is a problem. You'll have to adjust wheel offset with aftermarket wheels or spacers. Then you'll rub on the crash bars on either side of the wheel.
giovanni1
Ontario
OK thanks, could have been the 2026, not sure. But either way, I think you are right about the fitiment.
