Air Bag Warning Light
OldHippy
Michael
Central Ga.
2020 Ranger XLT 4X4
Anyone have issues with the AirBag light on instrument paneL coming on RANDOMLY? Mine started coming on riding down the road. Sometimes goes off after a few. Sometimes stays on till I stop and restart. Just curious. Thnx
RangerBill
PA
Is it a warning light or the passenger on/off air bag light below the radio? If a warning light in the dash, use a code reader such as Forscan to get the DTC codes.
OldHippy
OldHippy
Michael
Central Ga.
2020 Ranger XLT 4X4
It's the warning light not passenger on/ off. Thnx. I had thought about checking for code. Just hadn't had time to do it yet. Thank you sir.
Here
XLT
Hey Michael, My “airbag“ warning light used to come on once in while in my 4g Ranger. It ended up being an issue with a seat belt buckle and was easily resolved with electronic contact cleaner.
I hope your issue is just as simple to fix.
OldHippy
OldHippy
Michael
Central Ga.
2020 Ranger XLT 4X4
I posted a PID Data Ref here, just in case there are no codes, Pull up the data in the RCM and use the provided info as a guide.
(3) Airbag & Seatbelt System - (RCM) PID Data Reference | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
Thank you sir. I will check this out . I did get 2 alerts in my Ford app stating " restraint indicator lamp warning". It shows up 4 times over an 8 month period this is year . I will definitely use you info to check if I can see what's what. Thnx again
OldHippy
OldHippy
Michael
Central Ga.
2020 Ranger XLT 4X4
Thank you sir. I will Definitely check that out. Would be nice if it's that simple.
OldHippy
OldHippy
Michael
Central Ga.
2020 Ranger XLT 4X4
Not getting any codes. Damn thing just comes on whenever. I have checked all the seatbelt connections. They seem to be ok. But am going to get some cleaner and try that . Would you happen to know where the AirBag sensors are on the front end?
RangerBill
PA
What device are you using for a code reader? There should be a stored code if the airbag light is coming on. Cheaper readers won't read it. Forscan and an OBDII adaptor should read any codes for the airbag system.
With another member here experiencing the same issue, and no codes Using (Forscan)
Tells me that this needs a High-End Scan Tool to read it and or use the Live Data Monitor and look at the (Resistance Values) - something is teetering on the edge of specs.
This is something for safety reasons - it would be advised to get it on a better scan tool.
I have a hunch it's in the seat belt side of the system - bad connection
The list is too long to blindly T-Shoot this as for suspect circuit.
This is why I posted the PID Data Ref - To Assist in (Isolating) the circuit - without a code it's a needle in a haystack.
OldHippy
OldHippy
Michael
Central Ga.
2020 Ranger XLT 4X4
Not sure why. But, I buckled all 5 seat belts and, so far, the light has not come back on.🤔🤔. Been 3 days so far. I presume that there is an issue within one or more of the seat belt buckles. Just wanted to give an update. Thnx for all the help and other info. It has been great to get info from such technical experts that are in this group. Im Sure I will have more dumb questions before my 20 XLT and I separate. 🤣
Hmm - Process of elimination - Unbuckle (1) at a time, drive for a week or so for each one. and when the problem comes back - it may be the faulting belt.
OldHippy
OldHippy
Michael
Central Ga.
2020 Ranger XLT 4X4
That's a thought. Hadn't really thought about that. But believe i will. Thnx
