285/70R17 Nitto Ridge Grappler Hybrid Tire 217-710
Status
Not open for further replies.
Stage3Motorsports
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
Its been a little while since a tire post so here is another available tire option!
Ridge Grappler Features:
  • The ultimate hybrid tire
  • Variable pitch tread pattern to reduce tire noise at highway speeds
  • Shoulder and lateral Z grooves for better traction
  • Staggered shoulder lugs
  • Reinforced block foundation
  • Stone ejectors
  • Step block edges
  • Dual sidewall designs for personalizing
Fully Capable Hybrid Nitto Ridge Grappler Tires
Nitto's Ridge Grappler provides a comfortable, quiet, ride with the proper lugs and tread pattern to give you exceptional off-road performance. Tread quieter on paved roads thanks to audio equipment that was used to create a tread pattern that doesn't buzz nearly as much as a hybrid tire should. The Ridge Grappler comes standard with sidewall designs on both sides of the tire allowing for you to personalize your ride's looks. One side calls back to the traditional tires with traditional styling. The other side features a new aggressive block design. This listing is for a single tire. Dependable Off-Road Nitto Tread Design
Nitto's Ridge Grappler tires utilizes reinforced block foundation to add rigidity to your tread blocks. This reduces flex allowing you to tackle tougher obstacles. Stone ejectors in the grooves of your tread will prevent stone drilling that would otherwise wear down normal tires quicker. The shoulder grooves are arranged in alternating widths and lengths. The lateral Z grooves are placed in a zig-zag pattern. The shoulder groove alternating sizes and lateral Z groove placement prevents mud and dirt from clogging up your tread, allowing for consistent grip throughout your off-road excursions.
Tire Specs:
  • Tire Diameter: 32.76"
  • Max Load (single): 2756 lbs.
  • Tire Size: 285/70R17
  • Speed Rating: Q
  • Load Rating: P
  • Weight: 48.74
  • Stone ejectors
  • Step block edges
Tire Specs:
  • Speed Rating: Q
  • Load Rating: P
  • Weight: 48.74
Hi Frank...how does one search for specific tire size at your site? I like to see every offering for 285/70-17 for example...thanks!
Stage3Motorsports
Stage3Motorsports
Joel
Phoenix Arizona
Sales Specialist
Status
