2019-2022 Ranger 6ft Bed RSi EVOa Adventure SmartCap EA0304-MB
Status
Not open for further replies.
Stage3Motorsports
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
Still waiting on the 5ft, but if anyone is in the market these are now available!
19-22 Ranger 6ft Bed RSi EVOa Adventure SmartCap
EVOa Adventure SmartCap Features:
  • Extremely strong bed cap designed for extreme on/off-road capabilities
  • Double walled stainless steel construction
  • Modular design with a classic matte black finish
  • Innovative sealing method for weatherproofing
  • Installable/removable in just 15 minutes
  • Gullwing doors with integrated MOLLE panels
  • Rear half-door with flush-bonded fixed window
  • Comes with third brake light and uses factory third brake light to illuminate the bed
  • Backed by a 3-year limited warranty
Heavy-Duty Bed Cap Loaded with Features and Drop-In, No-Drill Installation
While even the most basic bed cap or bed topper is nice for bringing a lot of gear with you in a secure manner, most are made out fiberglass or composite that can't handle brutal off-road applications. That's where RSi's EVOa Adventure SmartCap comes in. The RSi EVOa Adventure SmartCap for 2019-2022 Ford Rangers with 6ft beds is made entirely out of heavy-duty steel and features a modular design that allows you to add RSi accessories to customize the bed cap to fit whatever adventure you have in mind. Moreover, the RSi EVOa Adventure SmartCap feature's built-in T-slot rails on its top, which allows you to expand your Ranger's cargo-carrying capability even further. Gullwing doors allow for complete customization of your EVOa Adventure bed cap by making it possible to integrate other RSi accessories like a Full-Bin for your tools or CampKitchen for feasting under the stars. Despite its innovative design, the RSi EVOa Adventure SmartCap is extremely easy to install and uses a series of specially-designed clamps to hold the SmartCap firm to your Ranger's bed without the need for drilling, cutting, or any other permanent modifications. The SmartCap even comes with a built-in 3rd brake light that taps into your truck's stock wiring.
Strong, Stainless Steel Construction with Large Windows and Built-In T-Slots
The EVOa Adventure SmartCap was built from the ground up to one of the toughest, most durable, and most capable bed caps on the market for Rangers. RSi manufactures the main body panels of the EVOa Adventure SmartCap out of stainless steel, which gives it much greater structural strength and durability than your typical fiberglass or composite bed caps or bed toppers while still being resistant to corrosion. Because of its steel construction, RSi was able to put 17% larger side openings than standard toppers, giving you easier and more effective access to all of your gear. The SmartCap comes standard with a Positive Pressure Air Vent that brings in fresh air into the cap which keeps dust out. The EVOa Adventure SmartCap also retains the factory third brake light for use as an interior cargo light so that you can find the stuff you're looking for after-dark. The built-in upper t-slot rails are capable of accepting t-slot legs from a variety of manufacturers, which allows you to build an entire t-slot based rack system on top of your SmartCap. The EVOa Adventure can support up to 330lbs of mobile weight and up to 770lbs of static weight, making it perfect for mounting a rooftop tent system. Each SmartCap comes backed by a 3-year limited warranty.
Fitment: 2019-2022 Ford Ranger 6ft bed.
For 6ft bed only: this version of the RSi EVOa Adventure SmartCap only fits 6ft beds. A version for 5ft beds is also available.
Grossgiant
Collin
2023 Azure Gray XLT FX4
Any ETA on the 5’ version of the adventure?
Stage3Motorsports
Stage3Motorsports
Joel
Phoenix Arizona
Sales Specialist
RSi is showing 65 in stock of the 5ft version EA0303-MB in their US distribution warehouse so we can get one shipped no problem. Reach out to me if you would like to order one up.
Joel
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Not to be gloomy but anyone wanting the 6 ft - and it looks awesome- better move fast. When I clicked on the link:
It says **DISCONTINUED** ?
Stage3Motorsports
Stage3Motorsports
Joel
Phoenix Arizona
Sales Specialist
5ft and 6ft are both available right now. We don't currently have either version of the Adventure active on the site, but I can still place orders on the back end for them, and both are now in stock after a very long backorder. Just reach out to me directly if you want to pick one up.
Status
