Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
2019-2022 Ford Ranger VSPEC Safari Snorkel System SS983HF
Highlights:
When venturing into extreme off-road conditions, the 2019-2022 Ford Ranger's intake can take a hit in performance if contaminants like water, dust, and snow get into your system. Tested in the extreme conditions of the Australian Outback, the ARB Safari ARMAX Snorkel System is designed to ensure foreign contaminants don't find their way into your airbox and engine while traversing deep water, dry dirt roads or intense blizzards. The snorkel repositions the air-intake to a higher location, reducing the chances of dust and water from passing through the airbox and filter, which can cause a massive drop in performance. Safari's CAD and lab tested Air Ram system is designed to remove the most water possible from incoming air and then deliver maximum airflow to your Ranger's engine. If you must cross a body of water, the snorkel works well to keep water out of your engine and reduces the probability of engine damage. The snorkel is modeled for a precision fit to integrate seamlessly with your Ranger and has a sleek, aggressive appearance. Keep your air-intake operating at maximum performance no matter how nasty it looks outside with the Safari VSPEC Snorkel System.
Built for Durability
Safari's snorkels feature a UV stable polyethylene body that provides durability and strength for a robust fit to the outside of your Ranger. The high-grade stainless steel and plated hardware provide corrosion resistance and durability while complementing the snorkel body for longevity. Safari's connection ducting is manufactured from EPDM molded rubber for a custom fit to the Ranger's body and is rated for up to 266-degree Fahrenheit continual operating temperature. These tough components keep you and your truck safe in the Outback or whichever treacherous path you find yourself on. All the necessary installation instructions and hardware are included to make installation easier. Upgrade your air-intake system with the Safari VSPEC Snorkel System to provide high-performance in any situation.
Fitment: 2019-2022 Ford Ranger
Notes: The Safari ARMAX Snorkel System requires cutting, trimming, and drilling of your Ranger's fender, A-Pillar, and stock air box for installation. See ARB's Install Instructions for details.
Highlights:
- Built and tested in the Outback's harsh environment
- Designed for maximum water/snow/dust sealing
- UV stable polyethylene body for strength and durability
- Air Ram system delivers maximum airflow to engine
- EPDM molded rubber connection ducting
- Rated for up to 266-degree Fahrenheit continual operating temperature
- Corrosion resistant stainless steel plated hardware
- Includes installation instructions & hardware
