White smoke
TJC
Thank you guys, still a whole lot of investigation to happen, as for the white smoke on that morning, it’s was plumbs of it, I had to pull over and once the smoke caught up with me I couldn’t see until I turned the engine off, it was really quite bad, although it was early morning and colder than normal. But when I did the leak test the other day it was mid to late afternoon and it was only smoking a little and I’ve never noticed it smoking previously.
That much white smoke is not good. Sounds like an internal coolant leak into the cylinders.... I think maybe the head gasket / EGR cooler proponents are correct. I'd check the EGR cooler first.
Best of luck
