Tire Help
FLRanger321
Matt
2019 Ford Ranger Lariat
Hello everyone, first post for me lol. I drive a 2019 Ranger Lariat 2wd. Currently have 2.5 inch Rough Country level kit installed and want to get biggest tires possible without messing with crash bars or purchasing any other equipment. I have 18 inch stock wheels that I plan on keeping on the truck. Was looking at 275/70/18 but not sure they will clear. Any advice or recommendations? Thanks in advance
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Tire & Wheel Specialists
Welcome to the site, Matt!
For no modifications to the crush bars, 255/70R18 and 265/65R-18 are popular options when combined with the O.E. wheels.
Brix
Atlanta
2019 Ford Ranger XLT FX4
I want to run the exact same set-up, curious to see what you go with.
HTX1811
HC
Houston, TX
19 Ranger STX 4x4,16 Audi A7
I put Nitto Ridge Grapplers on mine. 2.5” leveling kit. Mine are on 17” rims but I have zero rub. A 18” similar size will fit.
LT255 /80 R17. Zero rub at full lock forward or reverse. The tires measure 33” tall and 10” wide. This link is pretty good for figuring out actual deminsions.
tirehttps://tiresize.com/calculator/
FLRanger321
Matt
HTX, great site. I’ve been using it throughout this process. Looks like 275/70/18 are 33.2, and I’ve seen a lot of posts with people being able to squeeze in that size without rub. Do you think those will clear? Also adding 1.25 Bora spacer
HTX1811
HC
Houston, TX
I am not sure. I did not mess with any spacers because I just don't like them and for my application they were not needed. Personal preference. So I have not done any research about using them.
CVCA91911
San Diego
2019 Ford Ranger Lariat FX4
Maintenance Mechanic
I leveled my truck with Fox 2.0 coilovers. Then I changed out the tires to BFG K02 LT265/65r18. I’ve had no rubbing while off roading. The BFG K02 has a much better look to them than the stock tires.
FLRanger321
Matt
Those look great. Do you think I could get away with 285/65/18? About the same height
FLRanger321
Matt
Nope! Clear all the way around! Local discount tire did a great job!
Aragorn
2020 Ford Ranger Lariat FX4 Crew Cab
Will 275/65/r18 not fit? I was under the impression it would—without crash bar modification—with a leveling kit.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
On paper it's grey area. Much like shoe brands, tires can run larger or smaller even in the same size.
Take a look at post #9 and #11, OP didn't run into any issues with the factory wheels.
CVCA91911
San Diego
Update. Went with 275/65/18 Nitto Ridge Grapplers. No spacer yet but 1 inch bora are on their way
Very nice. Have you taken it off road to see if there is any rubbing?
I have BFG K02 265/65r18 with no issues.
