SiriusXM
UserHCC
Ohio
Ranger
Just because you have bluetooth doesn't mean you have sync.
Just tryin to help. :confused:
I don't understand that remark. Bluetooth? Anyway, I have the vehicle sticker. It says "SYNC, AM/FM RADIO, 6-SPKRS" under the equipment package.
Thanks for trying to help.
geophb
Mechanical Engineer
Well Im at a loss then.
I was under the assumption that all SYNC systems have siriusxm even in the 4 inch non touch screen models. Atleast in literally every other ford vehicle it does. I don't know why the ranger would be any different.
geophb
Mechanical Engineer
Okay so I was digging through the 2020 brochure. And NO where does it say sirusxm until the xlts.
Looks like you're right siriusxm is only on the 2020 xlts or higher.
Learn something everyday I guess.
That is some BS. My 2012 focus with base everything had siriusxm. WTF
Sorry bud.
UserHCC
Ohio
Ranger
Thanks for confirming what I suspected. I'll look into all the possible solutions and figure out what's best for me, and then post a summary.
UserHCC
Ohio
Ranger
I can not find any Audio Input jack, or Auxiliary Input for the radio. Am I looking in the wrong place? Or do some vehicles not have this? My vehicle has the smaller 4.2-inch non-touch screen.
JaysOnTheEDGE
Jay
Office Equipment Technician
The solution from VAIS that you posted on page 2 seems to be the best one so far listed. Shame on Ford though for not including the SIRIUS radio on all trim levels though.
slowmachine
New Hampshire
No idea if your specific model has one at all, but it would typically be on the back side, inside of the dash. It’s common to have to pull the radio out of the dash for access.
UserHCC
Ohio
Ranger
UserHCC
Ohio
Ranger
Pull the radio out? How can that be? The whole point of an audio jack is to easily insert and remove alternative audio sources. Are we talking about different things?
ldr01rl
Robert
TR Wisconsin
2019 Ford Ranger XLT 4x4
Get an XM/Sirius radio that has a headphone/output jack and add an FM direct adapter to the stock radio. As far as controls, you'll have the screen above the radio on the dash and the volume will be controlled from the steering.
UserHCC
Ohio
Ranger
I don't understand. The factory radio has no input jack. How would the FM direct adapter connect to it?
The other option would be to purchase a standalone SiriusXM radio (Onyx) and also purchase a bluetooth transmitter. Connect the output of the Onyx radio to the bluetooth transmitter, and use the Ford SYNC radio to receive that bluetooth signal.
ldr01rl
Robert
TR Wisconsin
UserHCC
Ohio
Ranger
I am the owner. I appreciate your help. Bluetooth is an option. Smart phones are not an option.
Okay, the FM Direct Adapter connects to the in-dash radio via the antenna jack, not an AUX input jack. That should work. However, I think a bluetooth adapter sounds easier to install.
I have heard that connecting an external radio to your in-dash radio via some form of over-the-air FM modulation is buggy, and generally sucks. I don't know if that's true, but it sounds credible to me. I would try bluetooth, then the FM Direct Adapter first.
ldr01rl
Robert
TR Wisconsin
I suggest picking up a receiver that can go from your truck to the home cradle. One single subscription to be billed for.
Bluetooth is like the FM transmitter/modulator, spotty but more reliable.
