Lowering a Ranger
Doc
Doc
Live oak fla
2026 5.0 Mustang GT, 2024 Ranger STX, 2015 Cadillac SRX
It’s abrupt! Will go all over the place in the rain. I’m afraid to hit it too hard because I don’t want to break the transfer case.
I had a 71 Chevy three-quarter ton four-wheel-drive truck in 1972. I was in Kettering maine temporarily in the military. I had to stay in a motel and my truck was parked in a parking space in the winter when I tried to leave the tires just spun. I put it in four-wheel-drive and sat there in place spitting the tires I had to get pulled out of my parking space.
GMtech
San Diego, California
2022 Catus Grey Ranger Scab XL
Retired General Motors Auto Tech
The rear is more straightforward.
However, my question is, if I lower the rear, what shim would you recommend I use, so that I maintain drive shaft angle alignment from factory?
Belltech offers anywhere from 1-6 degree.
I believe that Belltech offers the shims to correct the driveshaft angle, if I remember correctly, you want to keep the working angle of a U-joint at 3 degrees, any more than that you could get a vibration. Also, you do not want is an angle of 0 degrees, this will kill the U-joint due to lack of movement over time. They make a special tool to check the driveshaft working angle and I have used one a few times over the years working at a GM dealership, mainly for vibrations.
