Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
We just got these back in and after all backorders shipped we have 6 left, for anyone looking for a great little portable compressor setup!
Ford Performance ARB Portable Air Compressor Kit M-1830-FPAC
Highlights:
A reliable air compressor for inflating tires or running tools should never be too much to ask for. That's why Ford Performance offers the Portable Air Compressor Kit to serve your needs. Designed from the ground up to handle the most challenging applications on the planet, the ARB constructed High-Output Air Compressor is built extremely tough so that your off-road rig always has a supply of air no matter how hard you push it off-road. The compressor has a class-leading flow rate to inflate your tires and perform a range of other things. With a 19-foot air hose, battery clamps and and ARB air chuck with quick press fitting, you'll be all set to go. A durable carrying case lets you put away your compressor when not in use. High-Quality Components for Excellence
ARB's High-Output On-Board Compressor is built from the ground up for reliability and performance under even the most extreme conditions. The High-Output Compressor features a compact design that allows it to fit practically anywhere that's convenient on your off-road vehicle of choice. Each compressor is fully-sealed against the elements to prevent dust and moisture ingress from ruining your good time. Friction is reduced due to the hard-anodized cylinder bore. To increase lifespan, a Teflon-impregnanted carbon fiber piston seal helps. Lightweight, high-strength engineering-grade materials give the compressor a great use. For increased safety, an over-pressure safety valve helps keep you safe from high-pressure situations. Electronics can boost temperatures to dangerous levels, so ARB designed the motor to be internally thermal protected. A MAXI fuse also allows for a professional level in-line circuit protection.
Highlights:
- Compact and reliable air compressor
- Perfect to inflate tires & more
- Features class-leading flow
- Fully sealed design with high-quality components
- Includes hardware and basic instructions
