ARB Dual High-Output On-Board Air Compressor Kit CKMTA12
Status
Not open for further replies.
Stage3Motorsports
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
These have been backordered for quite some time and just became available again.
Powerful On-Board Air Compressor with Fast Fill for Practically Any Application
When any other air compressor kit just won't cut it for your extreme uses off the beaten path, the ARB Dual High-Output On-Board Air Compressor Kit is here to save the day. With two compact air compressors mounted in tandem, the ARB Dual Air Compressor Kit can output over 6 cfm of airflow, giving you more than enough air to handle your ARB Air Lockers, tire inflation duties, or power your air tools for any application you have in mind on the road or off of it. On top of its big-time airflow, the ARB Dual Air Compressor Kit is waterproof and built tough enough to survive practically any off-road challenge, making it the perfect choice for the avid off-road adventurer that needs and air compressor system that can handle the most brutal terrain on the planet. For its output, the ARB Dual Compressor System is surprisingly compact, and can be mounted just about anywhere on your vehicle of choice. This version of the Dual Compressor Kit is powered off a 12V source and comes with its own activation rocker switch. Each compressor features a pressure cutoff switch, its own air filter, a current load protection loom, and thermal load protection to help make it one of the most reliable air compressor systems. The Dual Compressor Kit comes with mounting hardware for installation.
Air Locker Solenoid Manifold Not Included: the ARB Dual Compressor System does not come with an ARB Air Locker Manifold, and one will need to be purchased separately if you're using this kit for an ARB Air Locker.
Compressor Specs (combined):
  • Current Draw: 50.4 amps
  • Airflow@0psi: 6.16cfm
  • Airflow@29psi: 4.68cfm
  • Maximum PSI: 150psi
  • Dimensions: 4.1x10.9x7.5" 17.4lbs
Stage3Motorsports
Stage3Motorsports
Joel
Phoenix Arizona
Sales Specialist
Dual compressor sold out fast. But the heavy duty single is back in stock!
ARB High-Output On-Board Air Compressor CKMA12
Highlights:
  • Compact and reliable ARB air compressor
  • Rated to handle up to a 37" tire
  • 100psi maximum pressure
  • Fully sealed design with high-quality components
  • Comes with universal mounts
  • Includes hardware and basic instructions
Multi-Purpose and Compact 100psi-Capable On-Board Compressor
Whether you're looking to run a set of awesome ARB Air Lockers or just want a reliable air compressor for inflating tires or running tools, the ARB High-Output On-Board Air Compressor is here to help. Designed from the ground up to handle the most challenging applications on the planet, the ARB High-Output Air Compressor is built extremely tough so that your off-road rig always has a supply of air no matter how hard you push it off-road. The compressor is 100psi rated and can handle inflation of up to 37" tires, and can fully inflate a 35" tire in under two minutes at its full duty cycle. The High-Output Compressor comes with universal bracket mounts and a complete wiring loom that allow it to be mounted practically anywhere on your vehicle. Fully Sealed Compressor with High-Quality Components
ARB's High-Output On-Board Compressor is built from the ground up for reliability and performance under even the most extreme conditions. The High-Output Compressor features a compact design that allows it to fit practically anywhere that's convenient on your off-road vehicle of choice. Each compressor is fully-sealed against the elements to prevent dust and moisture ingress from ruining your good time. The cylinder bore is hard-anodized in ARB's classic blue color, and the piston seal is made out of Teflon® impregnated carbon fiber that reduces friction to ensure trouble-free operation. The compressor comes with a sintered bronze air filter element that can be relocated to help avoid water ingestion. The Compressor uses anodized mounts with sound deadening to ensure minimal noise in the cab while the compressor's running. Each compressor comes with a wiring harness with a fuse, hardware, and general installation instructions.
Specifications:
  • Current Draw: 25.2 amps
  • Airflow@0psi: 3.08 cfm
  • Airflow@29psi: 2.34cfm
  • Maximum PSI: 100psi
  • Dimensions: 5.7" x 7.5" x 3.9" 7.7lbs
Stage3Motorsports
Stage3Motorsports
Joel
Phoenix Arizona
Sales Specialist
WyoRanger
Kymbrill
Laramie, WY
2020 Ranger Lariat FX-4
Automotive Retail
dwould you need anything else added to these to run air tools?
Status
