Dually Tire Valve Extensions for Freebie
From Grumpaws "catch all garage shelf"....
I have 4 dually valve extensions, from Dill Air Control, part #349. Their 6 inches long with metal caps.
Bought these several years ago for our then motor home with dually rear's. Never used them so still new.
No need for them now and will pass on to someone who can use them.
These are top of the line extensions, not el-cheepo knock off's.
Russd
jeff
Arizona
Vw bus 4runner
Interested. We have a motor home and I have fought filing the rear duals. One side has a flexible hose the other side I pulled off as it leaked.
Russd
jeff
Arizona
Vw bus 4runner
I think the outer ones I have are angled and not a big deal.
If you can use them, their yours.
Just PM me your name and mailing address.
Russd
jeff
Arizona
Vw bus 4runner
I think I would only need two tho correct? Just for the inside duals.
maybe someone else can use the other two.
thanks a bunch!
Two are claimed....
Still have 2 left .
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
Here in NY when we bought our motor home it didn't come with them. The next year when it went in for inspection it wouldn't pass until I let them add a set. I just carried a baseball bat the first year :oops:
I never had luck with the flexible type extenders. Eventually went to the dedicated type extenders that are bolted the the wheel.
Had these that were kept as spares, and used similar in the past...never had a problem with them.
To properly use them, they make a "rubber donut" for dual wheel valve extensions. Made to be used with steel wheels, they support the extension so it doesn't flail around.
Their listed (google) as either rubber donuts or rubber grommets for dual wheel valve extensions.
