Wolfbox
Diamond Sponsor
- Thread starter
- #1
Attention off-road enthusiasts and overlanders! We’re thrilled to announce the launch of our all-new Wolfbox HyperFlow 60D Air Compressor—a game-changer for your air inflation needs. Designed for durability, efficiency, and high performance, the HyperFlow 60D is built to handle even the toughest challenges. Here's why this powerhouse should be your go-to air compressor.
Purchase on Wolfbox site!
Purchase on Amazon!
Why Choose Wolfbox HyperFloew 60D Air Compressor?
Performance at Its Peak:
Purchase on Amazon!
Looking for an On-Board Air Compressor?
If you’re into onboard setups, check out the Wolfbox HyperFlow X for the ultimate convenience.
Don’t miss out on this incredible deal—gear up with the Wolfbox HyperFlow 60D and conquer the trails without worry!
Available Now: Get yours today and experience inflation like never before!
Purchase on Amazon!
Purchase on Amazon!
- 100% Duty Cycle: Can operate continuously for 60+ minutes under full load in 25℃ environments without stopping.
- 40℃ High Heat Resistance: Performs exceptionally even in hot climates, working non-stop for 40 minutes.
- Innovative Cooling: Dual-side active fan intake with an open heat dissipation design keeps the system cool under pressure.
- Extreme Durability: Built for continuous high-load operations, with a core life of up to 80–100 hours.
- High Output Performance: 5 CFM @ 40 PSI, ensuring quick and powerful inflation.
- Perfect for Large Tires: Designed for 35–40” tires—inflate a 37-inch off-road tire from 10–40 PSI in just 3 minutes!
- Auto Shut-Off: Set your desired tire pressure and let the compressor do the rest. It stops automatically with only ±2 PSI variance.
- Multi-Wheel Inflation (Optional Accessory): With a high-pressure air source splitting into four independent airways controlled by solenoid valves, you can perform single-wheel, multi-wheel, or four-wheel simultaneous inflation. (Requires additional 4-Tire Inflation & Deflation System.)
- 120L/min flow rate at 40 PSI, ideal for fast and efficient inflation in every adventure.
- Regular Price: $369.99
- Introductory Price: $329.99 (Limited time only!)
Purchase on Amazon!
Purchase on Amazon!
